Looks like you are talking about a C4, in this case the pump access is in front of the battery, in the cupboard last part of the front trunk.
RFM,
Thank you.
I thought C4 by the label on the tank.
Access through the trunk ( inside the seal) or still in the "open" area around the battery?
Access through the trunk, inside the seal, under the black plastic rectangular cover on top of the cupboard.
