Front end feels like falling off
i jacked up car and can rock the tire from side to side. It moves about 1/8 inch on both sides. Really rough ride at all speeds on roads with any bumps or pot holes. Front end feels like it is going to fall off. Any ideas....possible bushings or controls arms....80,000 miles...thanks
You can't see anything move if you get under it and shove a wheel around?
It would be quite a coincidence if each wheels suspension components went out with the exact same symptoms, independently, and at the same time. I would look for something they both share... like the steering rack or something.
Regards, PK
