Started the coolant pipe replacement today. Got the belly pan off and radiator support/guard and no sign of a drain plug in the radiator. I am looking at two black rubber tubes which go into an aluminum housing with two metal tubes coming out of it but no plug top or bottom and nothing in the radiator itself. The rubber tubes look to be a compression fit with a screw holding a "keeper" plate over the top of them. I cant believe it has taken two hours and I dont even have a drained radiator! The only thing I can think of is that something has been replaced with a non-oem part. This is a 2006 TT.....
Desperate in Florida
I think that what I am looking at is the Tiptronic oil cooler thermostat and lines. Cant see any other way than pulling a hose off...
PKN
Unfortunately, I ran out of time and had to put it back together again. On the far right and bolted to the bottom of the rad, two rubber tubes that look like power steering hoses go into an aluminim housing, the other end disappear along the side of the motor. On the other side of the aluminum housing, two metal pipes are bolted on and they curve around and disappear behind the radiator. I looked into PET and I think this is a thermostat and carries oil to cool the Tiptronic unit in the transmission.
Strangely enough, thogh PET says it covers 2003 to 2006, the section on draining the rad only goes to 2005. I suspect that this radiator does not have the petcock. I will try again next weekend I have free but will have to release the coolant from either the thermostat housing or one of the hoses.
Many thanks
PKN
Problem solved - the 2006 Cayenne TT does not have a radiator drain fitted !!! My Porsche dealership tells me they are only on the car up to 2005. The tech said pull the bottom hose - easy when you have a lift, messy when you dont. I asked for a price to replace the coolant pipes if I supply the kit - answer $1300 for the turbo and $1000 for non-turbo at $100/hr. I will call a local indy tomorrow to get a price but I think I will take care of it. I would rather spend the money on a window A/C unit for the garage
PKN
