Seeking Replacement instructions for rear seat belt receptacle replace
My rear seat belt receptacle failed this weekend (failed to latch) and I need to replace it. I'm guessing that this is a simple job, but a quick search has not revealed any instructions on how to do it. I would appreciate it if someone could point me towards instructions on how to do the replacement.
I have a '99 C2 and the buckle that needs replacing is on the driver's side.
Thanks in advance!
If this is a rear seat buckle it's really simple.
Just pop off the bolt cover (#6 below) with a cloth and flat head screwdriver. On my car it's held together with a couple friction fittings, so it literally just pops off.
Then use a torx bit IIRC to remove it, but it could be hex - it's been a while.
It is a large bolt and requires quite a bit of leverage.
Not sure about tightening torques.
Edited by logray
Excellent! Thank you! That's a huge help! I'll tackle it this weekend!
