Rubber dust seals
Hi, I'm in the process of replacing the rear axle shaft assembly. In trying to take apart the ball joint on the axle strut (wishbone) that connects to the wheel carrier I've ripped up the rubber dust seal. Is there a way to repair this or replace them? What is the part number for the dust seals or do I have to replace the entire axle strut? Thanks.
2001 Boxster S
