Convertible top will not close
Hi all,
My 2003 996 cabrio has the following intermittent problem:
When I try to close the top via the dashboard switch, the roof cover opens but then the process stops - the top does not start moving up/forward. This happens every now and then, and usually if I open the top and close it again it works.
Other than that the roof is working fine - no noises, not struggling at all etc.
I assume the problem is with some kind of sensor that tells the car that roof cover is fully open, but I cannot find where that sensor is to check if it working properly.
Any ideas?
Michael
1 - Rocker switch
2 - Warning light
3 - Micro-switch, latching hook (windscreen frame)
4 - Micro-switch, convertible-top latch (convertible-top side)
5 - Potentiometer, convertible-top interrogation
6 - Control module
7 - Micro-switch, convertible-top compartment lid (locked)
8 - Potentiometer, convertible-top compartment lid interrogation
9 - Micro-switch, left/right rear section flap up and down The convertible top is actuated if:
8 Terminal 15 is connected via ignition.
- The parking brake input is connected to ground (parking brake engaged).
- No speedometer signals greater than 5 km/h (3 mph) are present.
- Engine compartment lid is closed (input not at ground potential).
