Replacing Fuel filter
Filter location underneath the rear seat behind the driver side Replacing the filter: Recommended to do this job while the fuel tank is almost empty Fuel tank located underneath back seat Gain access to fuel filter need to flip back seat and look under the carpet Pull the seat buckle below the seat and flip the seat bottom Remove seat mount hinge, note you need special socket to fit the nuts Find below a round cut made on carpet, open Find round stainless steel caver with four sc
Edited by abusharkh
  • 5 years later...
I think I will need to do this.  How much was the filter?  from where?  Should I assume to do both at same time?  While Im at it?
Thanks.
  • 4 years later...
Just had to replace mine, '08 CayenneS.  It developed a crack and started to leak after 134K
