Hey guys... I'm looking for a part number or source for the red bushing that holds the power steering return line to the power steering pump. Mine was cracked and missing a chunk resulting in expensive fluid leaking all over the top of the engine case. Are there any workarounds that can be done to eliminate the problem? I have read a couple of posts indicating that the bushing can disintegrate under hard usage of the steering (track day and such).
Also... I had a devil of a time trying to get the line out of the pump, and pulled out the brass collar that the hose/bushing goes into. Is my pump toast?
Well I'm having trouble locating those parts as being available separately from Porsche.
You might need to replace the pump reservoir if that's where the hose is going into.
P/N 99731422000 MSRP $82.87
Edit, you might also have to replace the return line that goes into the pump reservoir, if that is damaged 98634743906, MSRP $55.20.
Or are you talking about the line that goes into the pump itself, not the pump reservoir?
Edited by logray
