Another "Buying a Boxster S" question...already searched
First post, so sorry if this is a vague question. I'm buying a 2005 Boxster S, and the carfax shows the following:
04/29/2008 48,650 Porsche Of Orlando
Maitland, FL
407-262-0800
orlando.porschedealer.com
rlando.porschedeale
r.com Engine removed to complete repair
Antifreeze/coolant flushed/changed
Alignment checked
Cooling system checked
Camshaft(s) replaced
Washed/detailed
Body computer/module checked
Is this good or bad news? Thank you in advance for any input.
The dealer should be able to find out exactly what was done to the vehicle. Although Porsche is a great car they are very expensive to repair. If at all possible I would look for a certified pre owned Porsche. The added purchase cost for this is well worth it. The 986 Boxster has had some serious engine IMS failure issues. There are different opinions on what percentage of engines have failed but it is agreed that engine replacement is somewhere around $15,000. Good luck.
