coolant tank wire position
I cannot seem to find a direct answer so here goes - what position should the wire pressure relief on top of the coolant tank be - straight up or over to the side. It seems that in the up position it 'locks' in place with the top of the valve. I think it should be up to bleed and down (over to the side) all other times - is that correct?
Simple question and hopefully a simple answer. Thanks!
