I recently purchased my 1st 911 and I was interested in getting the calipers powder coated red (they are currently black). Any recommendations? How much should I expect to pay?
Also, how much should I expect to pay for new brake pads?
Jarrod
Norman, OK
My Webpage
I will like to do the same but I will like to find a company with an exchange program. Send me powder coated caliper with new seals, ect. and I send the tire old ones.
My friend and I are also interested in doing this... Maybe we can get Eric & www.bumper plugs.com or somebodyelse to do a Group buy discount????
I want to make sure too that the porsche sticker/emblem is also back on after repainting them...
Paul
San Diego
I talked to someone today about powder coating the calipers and he said that the do it yourself paint kits are better because they use high temperature paint (and they are cheap). I checked into it and you can get the paint in any color @
http://www.departstop.com/Brake%20kits.htm
and if you want the stickers, you can get them at
http://www.renntech.org/forums/index.php?a...re&code=caliper
Jarrod
I tried that heat resistant paint on my lexus IS300 and it faded fast... I had to re-do it a couple of times before I finally gave up...
Eric is right, let's do it right... I'm sure we can get a group discount somewhere. (I have 2 people interested here in SD if the price is right.)
Paul
1999 C2 coupe 3.4l
  • 4 weeks later...
The other day I spoke with Eric @ Bumperplugs.com and he said that his caliper guy quit. . . and that he is searching for a replacement.
Paul
Let me get to work on this and see what I can do for you guys.
I'll post back here as soon as I have info, and for those interested, we'll get started.
Thanks.
Count me in on a set for a 1999 C2! Let us know what colors are available!
Jarrod
I used that paint on a 2000 Corvette C5 to make the calipers red. I will say that the paint is very durable and did not fade at all. However, the paint is put on with a brush and it's very thick (it dries quickly which means you have to work quickly and it will get thicker before you can finish all 4 brakes). This was fine for the Corvette because the calipers had a very rough finish on the metal of the calipers and it hid the less than perfect paint job. But the Porsche calipers are smooth and will show all the brush strokes and variances in paint thickness. So I don't think it will look as good.
But it might be worth a try before going the powder coat method if you are a skillful paint brusher, because it's cheap and can be done without removing anything but the wheel and masking the rest off. If it doesn't look good, just send them off to be blasted clean anyway since that's most likely what they were going to do to the original black paint anyway.
Thanks.
I would be interested!
  • 5 weeks later...
I bought red caliper paint from Auto Zone, bought a fine paint brush from an art store. I prepped the caliper, wet sand, and primer with spray paint, and applied the red paint with the brush. I was very pleased with the result. Got the decals on ebay and clear coated them on the calipers. Total cost $25 and one days work, reward awsome.. unless you want to pay $500 and not drive the Pcar for a couple of days. If you don't like the result you can always have them done.
I have decided to do it the correct way the first time, therefore will be powder coating as well.  I plan on sending my caliper to
http://www.merijons.com/
I was quoted $200 for all four
You will need to get your calipers rebuilt though, so factor that price in. Merijons does not do the rebuild.
Guys ... keep in mind that you cannot get factory rebuild parts for your calipers. The ones that Porsche offers are outer dust boots only.
I powder coated mine and it took me weeks to find inner seals that would work. There is a good chance that you will have to buy new calipers if you lose your inner seals.
Dan
