Boxster 986S Driver Fwd Window Clamp Problem
One recent hot day caused the exterior rubber outside the Drivers window to stick.
This caused the front clamp to lose it's grip and came undone while lowering the window.
I have the panel apart but the Torx screw simply spins and I am unable to tighten it against the window.
Is something missing?
The rear one is intact and has something black on the other side of the screw.
But I don't see anything of the sort at the front.
Any advice?
Wow!... ZERO replies.
I figured it out. I should have taken a photo.
If you back the screw too much, as I did, the clamshell clamp will dislodge. With the window up, I had to reach my hand way up in the panel to reattach and realign the back end. I pulled the back portion all the way out first to have a look-see, tilt it back slightly and lift up to remove. The rubber pad, used to protect the window, got slightly twisted in mine. I had to reset it properly in the clamp, easy to do.
I replaced the back end of the clamp and, you need to hold this in place w/one hand while you set the scew with the other hand.
The window seal shouldn't be binding, maybe best to replace it as it sounds like it's the source of the problems.
I believe you are right. It will just happen again. I believe the material that presses against the outside window has deteriorated.
Thanks for the suggestion!
