I need to replace the battery on my 987 am I right in thinking I need to put the key in the ignition and turn the power on (but not engine) before disconnecting the battery to replace to prevent the alarm going off?
Hi there. No you don't need to do that. Just replace the battery like normal.
When you put the new battery in you might need to enter the radio code, reteach the windows, and it will take a few drive cycles before the engine is back to it's normal "peppyness".
Cheers, so to remove the battery its black terminal off then red terminal off (remove battery and insert new one) then red terminal on then black terminal on? Do I need radio codes for a CD24 on a 987?
UK cars have the tilt sensor and alarm siren. I'm not sure about the 987, but on a 986 you have to switch the ignition on before disconnecting the battery, otherwise the alarm siren will sound.
Yes. Disconnect the negative (black) first, and then the positive. Reconnect positive first, then negative. This prevents shorting out.
The CD24 doesn't have a user-entry security code.
Edited by Richard Hamilton
Agree with Richard, all EU-spec. 986/987/996/997 are equipped with alarm siren, you have to switch the ignition on before disconnecting the battery.
