2004 cayenne s fan doesnt turn on
i have a 2004 cayenne s im having problems with my fan it doesnt turn on it runs cool like 180 on the freeway but when i start sitting on traffic it starts to heat up and the main fan doesnt turn on i just chage my water pump thermostat and water temp sensor i wonder what it is fuse relay or what if anyone could help o by the way i upgraded the cooling pipes a while back
Edited by 87#184saleen
My first thought would be to check the wiring and/or the temp sensor to make sure it is the correct one if it isn't working. The fans are fused also, check your manual as mine is a '06 so it is most likely a different fuse.
Edited by hahnmgh63
