Swap to 997.2 GTS motor is possible ?
I don't know for sure but I highly doubt it.. The 2010 DFI engine is a completely different engine than the 997. Mounting will be different and for sure the electronics will be..
I would call around to some high end Porsche tuners in your area and ask them..
With enough money, time, and welding equipement, anything is possible. Question becomes “Is the view really worth the climb?” Some time back, an advetursome sort tried to put a late model 3.8L Turbo engine into an early Boxster; before he was anywhere near finsihed, he had already spent more than it costs to buy a new Turbo car.
Along with all the elelctronics, you will need to replace the entire fuel system as your car runs around 50 PSIG, while the DFI motor is running close to 1700 PSIG……
