Strange side marker behavior after installing LED light (electrical)
So, I tried (keyword) replacing the front side signals (blinkers) with canbus LED bulbs (built-in load resistors).
After I put the LED bulbs in and I turn the lights on (parking or headlights), the side lights no longer light up. The tail lights will come on, the city lights come on, but nothing from the side markers (the orange light housing that most everyone do as their 1st mod). Anyways, the lights will blink fine (I had it re-programmed to blink as indicators) when I put on the turn signal, hazards or arm/disarm alarm. But the lights won't come on now. Even more strange, when I put the incandescent bulbs back in, the incandescent bulbs also do not come on (again, they blink just fine with turn signal/haz, etc.).
I just quickly tried with a (low end) volt meter to the bulb socket and it seems I get a steady 10v when I turn the lights on, but and nothing changes when I turn the lights off and on again. What should I be looking for? It is as if there isn't sufficient current/power going to the LED or incandescent bulb to power it. I have since put the incandescent bulbs back in, disconnect the battery for about 15 sec, try again... but still nothing changed. Any idea/suggestion? Thanks!
Edited by lithium1330
There might be a fault code in the front control module, the computer thinks there is a problem so no longer activates the ground path for the circuit. Check for codes, clear any and check operation.
