C4SFrontcV.movHello Renntech,
I have tried to identify clunks and rattle on my C4S
After having changed everything in the front I still get a rattle when traveling at low speed
Here is the list of what I changed:
_Suspension, Top bushing, suspension bearing,
_inner and outer steering tie rods, all control arms, steering rack,
_sway bar bushing, say bar links
The only part that is not new are the CV joints which to me have an abnormal play, not when turning it but pushing and pulling along the shaft as per attached video
The car is now 85 000 Miles
Could you tell me if this is normal?
Hi Everyone,
Since I started to learn about CV joints ( see previous post), I tested the rear ones too as I get a light "click" whenever I give gas
When I move the wheel and put my hand on the inner CV joint, I do fell that the noise comes from the joint but the differential is just behind and it is not very clear, the differential is new as I got my tiptronic changed recently, also there seems to be no play between the joint and the shaft, see attached video
Do you think it is time to renew them, my car is 85 000 Miles, or is this normal
The other side seem to be also making noise but then again, the differential makes noise on the other side and it is not obvious to locate the culprit
I would have believed that if I make the shaft slide the noise would have changed, but it keeps on being the same, so maybe this is just the differential or maybe this is just the normal noise of CV joints?
Let me know what you think about the mileage and 911 CV joints.
C4SCVrear.mov
Your post #1: the cardan shafts have Always slack in the longitudinal direction, otherwise the wheels can not go up and down, so normal. I can not open the video in post #2, no permission according the forum.
Thanks RFM, I know about the longitudinal move on the rear ones ( about 3 to 4 cm move), but on the AWD 911 the front CV hardly have play
The left one would have 1 mm where as the right side would have around 5mm
The difference with the rear is that you hear this "Clonck Clonck" everytime you move the CV shaft, on the rear ones you feel that the movement is dampened by grease in the CV joint, it must be a different system
Hence my question: is this normal ?
My rear potential CV issue is all different, I hear a slight clonk when I give gas, the same noise can be reproduced when I lift up the car, now I don't know if this would be the differential or not
I will try to post again the video
The noise seems to come more from the differential which is not abnormal in such a short fort and back movement of the wheels. It remains difficult from behind a PC screen to Judge, even with video, the lack of physical contact with the car plays a not insignificant role. I would go with an experienced technician for a second opinion if i were you.
Hi Brendel,
This is the drivetrain lash I refer to in another thread. My car does exactly the same thing and it only has 14,000 miles on it. The Porsche tech says this is normal or rather that the car is performing to Porsche spec I am 95 percent certain that it emanates from the transaxle,
