2005 CS Power Steering Concern
Squence of events:
- CS parked overnight in garage
- started engine - normal
- open garage door
- put tranny in R
- backing up slowly into back alley
- as I was backing up I tried to turn the steering a bit, wheels pointing to the right
- felt the steering very heavy as if the power steering was not working
- when i was out of the garage and into the alley, I turn the wheel fully to the right
- at that point the power steering was normal
- then I proceded to turn the steering to the left to go down the alley, it was normal.
So was this brief absense of power steering normal in a CS at startup?
Power steering fluid was normal.
No puddles on the ground (yet).
There is a TSB: Servotronic Control Unit: Steering is Hard and Stiff After Starting the Engine 13/08 ENU 4869 4
The TSB is 2006 up to 2008. Not sure if your CS is a late '05 it may apply?
No jokes about the title please :)
Edited by hahnmgh63
