I am Maarten from Amsterdam, NL. I drive a 2003 Cayenne turbo that has a faulty air suspension. I had the yellow "airsuspension faulty" message a couple of times over the last two years but now the car "lies on the floor" with a red airsuspension warning.
Compressor is not running, when I connect the spare tire hose: no pressure either. When I bench-test the compressor directly it runs fine. At that point I decided I need a diagnostics computer and bought a Durametric kit.
I get the following error messages from the Level Control module:
2250 (valve operating time exceeded, upper limit value exceeded)
1575 (manual control switched of)
778 (steering angle sensor, No signal/communication)
[Cornering lights do not work either]
1487 (System function test faulty, Implausible signal)
1772 (Signal lead for pressure sensor, Implausible signal)
When I try to read the actual values, I see things like compressor temperature and Compressor relay (off). I also read "System Status Number Control Mode" which reads 4010. "Deviation from normal level" and "absolute vehicle heights" also show plausible numbers.
Battery is in good shape.
When I scroll further down, there are many signals that do not show any values and that seems strange to me: "Accumulator pressure", "Terminal 15" all stay blank. Maybe these are simply not supported by Durametric?
Any tips? Where is the pressure sensor located (related to 1772)?
Can I start the compressor manually to fill the system? I know the Porsche tester can fill/bleed the Level Control System
Thanks in advance,
Maarten
  • 2 years later...
Thanks in advance,
Maarten
This is an old post, but I recently had a similar issue.
With Durametric you will go to the coding tab for the Level Function and calibrate... The sensor which does not accept your coding is the sensor which is bad....
  • 8 months later...
