Help...
I switched to my backup set of keys and the passenger mirror tilt on reverse is not programmed to the position as with my other set of keys.
I looked in the my user manual page 49 and all it say is to move mirror to any position when in reverse. When I took the car out of reverse, it did not move back to normal drive position so I manually adjusted mirror back to normal driving position, then put car in reverse, and the mirror moved to the wrong setting again.
When i switched back to first set of keys, it works fine.
I searched the forums and can not find detained instructions for setting mirrors.
Al
2001 996
Check your manual for "Seat Memory" (p34 on my '03 manual). You have to put the car in reverse gear when programming the seat position to a memory slot.
