Hoping someone can help, we just picked up the wife a 2005 MY06 997.1 Carerra S with PCM 2.1B with Software Version 3 including Navigation and phone sim slot and we're trying to figure out definitively if it can it play MP3 cd's?
I've searched and read the posts but I'm just more confused.
I have the following unit info for the system and software and can post the Amp / CD Changer and Nav if required.
PCM
Target and Actual are: 05024AD1 / 0205
System Software
Target and Actual are: 04364AD1 / 3604
Does anyone have a definitive answer if this unit can play burned MP3 cd's and if it is yes then a guide to what software you used to burn the mp3's and in what format; folders for albums or single files,and also any special way to close the cd burning process.
Thank you in advance for any replies and info
Cheers Al
Edited by quozl
No, not in mine either, same model as you have. Dension or go down the scrap the PCM route. Personally gone Dension 500S as I wanted to retain the originality.
