It looks like I will need to replace my fuel door actuator. Since I will be working in that area, I would like to do something about the fact that I cannot fill my tank completely. I usually get between 3/4 and 7/8, assuming that the fuel gauge reads right.
I have read a few threads on this forum about not being able to fill the tank at all, due the failure of the tank vent valve. My case is different; I get a partial fill, but I wonder whether a partially failed vent valve could still be the cause for not being able to fill the tank completely or the problem is due to something else.
