I recently did a 40K mile service on my 2008 Boxster, and now my CDR 24 radio is not working. I checked fuse D9 - it appears good. I get a blinking red light on the front of the radio, but no other power indication. Durametric reports the following errors:
C131: Communication gateway control unit (CAN comfort)
C141: Communication PCM (display)
C144: Communication CDR (display)
C150: Control unit communication engine electronics (drive)
C152: Communication PSM control unit (drive)
Everything else seems to work fine, despite these codes. Is there a relay or a different fuse or something else I can check?
All these codes are power related - make sure you have checked all fuses (with an ohm meter). As well check the power connectors to the CDR-24.
