Hi everybody,
I have new navigation drive from crashed car: 996.642.122.03 EFR. I assume it is 16bit? If so, is it compatible with main unit? At least the cables fit.
I have heard that I need 2002-1 disk to update with drive and then could use the Opel maps.
This is old story for most of you. As a green member, I had hard time understanding what to do :(.
Is that disk image available somewhere and does it help at all? Or do I have to change main unit too.
I appreciate any info you have.
Thank you from rainy Finland!
BR. Marko
Hi Richard
Still "little bit" struggling with my PCM1 & navigator. I now took also the PCM out to see the version. You can see them in link: https://plus.google.com/107888625339303820635/posts/BKX8Sf85Unh
Navigation unit is in pieces and I have problems to make it work. The main issue is if these two are even compatble? Is the PCM1 too old...
Any idea?
BR. Marko
