Hi all I need to immobilise a Hybrid
I would normally do this from the brake switch wiring, but on this model you can disconnect the wiring to the switch completely and it will still start .
So I am thinking would it be possible to use relays to fooling the car that the brake pedal is not pressed when in fact it is
Because if you try to crank the car in foot off brake pedal there is no crank and also the gear-lever is locked in PARK
So perfect just need help with how to wire relays please
