Hi Everyone,
I have just done the serpentine belt on my 2003 CTT, but in replacing the Y pipe, the small pipe that is on the bottom broke off. I have epoxied it back on until I can get one from my dealer. My question is where does the venturi line actually go? Just a little worried if I drive the car and the epoxy fails what is likely to happen? It is item 4 on the image
is this the one that Tees into 2 metal lines behind the manifold?  If so that connects to a vent line to each turbo.  You're fine running it as it isn't safety critical.  But definitely get it fixed sooner rather than later.
