This has been on my mind for a while now. I'd like to purchase 22x10.5 wheels in the back with 305/35r22 tires and 22x9.5 in the front
With 265/35r22 tires for my 958 Cayenne S. If anyone could help I'd appreciate it.
Edited by Stuttcartz
Just correction
22x10.5" rear wheels will fit fine on the rear with an offset range between +45 to +55. The tire sizes you listed aren't appropriate for any Cayenne - these vehicles require the front and rear tires to have exactly the same overall / rolling diameter; the tire sizes you listed have very different overall diameters. The most popular 22" sizes are 285/35R22 or 295/30R22 for use front and rear.
4 hours ago, Stuttcartz said:
So you're saying I'd have to get those sizes all around?
Yes - go with 22x10.5" wheels and 285/35R22 or 295/30R22 tires all around. If you are able to specify the offsets, and assuming your S doesn't have extended wheel arches, I would go et55 front and et50 rear.
