After coming back from a trip I found the battery had died. After charging I noticed that the auto up on the passenger side has stopped working from either side of the car, and I can also start the car without pressing the clutch pedal.
Any ideas?
:welcomeani:
You need to re-train the windows.
Hold the Down button until the window is all the way down - then hold it for 10 more seconds. Do the same for window up and you are done. One-touch should work again.
