2002 S Cruise Indicator light bulb?
Does any one know if the 2002 cluster has a replaceable bulb for the cruise indicator or is it an LED and not replaceable?
I recently upgraded by adding 3 position cruise stalk to my car and completed the wiring job.  I programmed the DME and cluster with the Durametric Pro and the cruise works great, but I do not have a light on the instrument cluster that comes on.  I have read posts that say it could be a bad or missing bulb but I think that is for the earlier style cluster that is not LED.  I have also read posts that state sometimes the Durametric programmer will not activate the CAN bus for the light and only way to get it working is to program the car with a PST2.    It does not come on when I turn on the key.  (FYI, I did not install the extra wire from DME to the instrument cluster as noted in the Pelican article as that is only needed for the early style cluster and not shown on the 2002 wiring diagram.)
Dave
PET shows the instrument cluster bulbs only for cars up to 2001.  You are also right that the 2002 doesn't need an additional wire from the DME to the cluster - only wires from the stalk to the cluster.
It sounds like it might be a coding issue to me, and I think you should track down someone with a PST2 or PIWIS.  Get them to check the Order Code is saved in the DME Vehicle Data, and then re-recode both the DME and cluster.
