Team, need some help.  I have a door locking issue.  I cannot lock my drivers side door with the key fob.  When I press the "lock button" on the key fob, all doors lock except for the drivers side door.  The alarm even sets.  When I open the driver side door, the alarm sounds.  I stop the alarm by using the key fob.  The only way to lock the drivers side door is by using the actual key that's inside the key fob.  When I use this key to lock the door, the alarm chirps twice and all doors lock.  When I try to unlock the car using the key fob all doors unlock except for the drivers side door which I have to use the actual key to unlock.  Has anyone experienced this issue.  Any assistance will be greatly appreciated.
  • 3 years later...
I suspect it is your door actuator, needs replacing.  I did the front driver side door.  Not too hard, takes time.  Even wrote a DIY for it.  Maybe can get to it and post on here in DIY section.
