P0420 is the bank1 catalytic converter efficiency too low and has nothing to do with the O2 sensors, which have their own codes.
You can use an OBDII scanner to monitor the signals of the O2 sensors on bank 1 to confirm the cat is indeed bad (when the post cat signal follows the swinging precat signal, the cat is bad). The only fix is to replace the cat.
Edited by Ahsai
You may want to try ebay for a used one. It's rolling the dice without an easy way to verify if it works before you put it on your car. I usually look for ones that were taken off lower mileage wrecked cars.
You can search for "2004 boxster downpipe" on ebay.
You're welcome. It's likely you have the same problem on the other bank then.
You may also want to check out this thread for more info
