  • 3 years later...
I've scoured the net looking for this answer and it was here all along =b  thanks Loren ...
Now to pick your brains a little further, I've had the 1299 Gateway code from the get go when I bought this 06 Cayenne.
The only things not working where the rear wiper & A/C  (a couple years now)
Recently a mess of 18 codes popped up after sitting a couple weeks (really nice top down days in the Boxster =]
After mulling through with the Foxwell & Durametric, I narrowed down to 1299, 968, & 538 codes ...
I've had the carpets up, dry as a bone, and no splices ...
Had a look at the Gateway board, nothing apparent, checked all grounding terminals I could find/see.
I can do without the R-wiper and A/C, but now not having the blower motor running, I have to sort things before the weather changes.
So I've ordered another multiplexer gateway....
Would you have any other thoughts/suggestions to add?
Thanks in advance!!
A common is on the 9x6 cars is foam liner from the HVAC flaps getting into the blower motor. If enough gets in there it can cause motor to stall and/or fail.
