oil temp fault on my dashboard which is causing problems with oil level reader ( basically keeps cancelling when it counts down to o seconds so you can't see actual level).Less than ideal.
Assuming I need to replace oil level sensor.Where is it ? and how easy to DIY ?
Welcome to RennTech :welcomeani:
You did not state the year and model of the car, but on most the oil level sensor and temp sensor are the same device that is underneath the intake manifold, which has to be removed to extract it.
