N/S Window Not Dropping
Hi, have 2002 boxster, the n/s window does not drop when the door is opened , I can hear what sounds like a motor when the door handle is pulled but the window doesn't drop. The window works from switch inside car but going down it finishes with a bump and going up at about two thirds it makes a grinding noise like the glass is being scratched which it isn't.
