Anyone having stalling issues, stumbling and no power?
Maybe this issue is old news but as it turns out the fuel pressure lines in the tank in my 04 TT Cab had split and not delivering enough fuel to the engine. Thought I'd share in case anyone is going through the same thing. It did not send a code so it was hard to diagnose.
Edited by James Fields
  • 11 months later...
Yes - (realize old thread) - longer to start, cutting out at 3K+, stumbling, off idle stumble, etc. - no codes.  Replaced filter, got worse and won't even idle.  Order new sender, pump, feed lines, tank neck seal from Sunset - waiting for parts.
Car is 2001 tt, coupe, manual, 90K miles.  Sat for a long time bf I bought recently.  Ran awesome during my test drives:-)
