I am new to this forum and a new 986 owner.  My 986 was purchased know there will be issues to deal with.  One issue is the fuse blows when I try to manually raise the rear spoiler. Anyone have this experience.  Is it a switch issue or faulty motor?  Any comment welcome and appreciated.
Welcome to RennTech :welcomeani:
Does the spoiler only blow the fuse when you hit the manual switch, or does it also do it when it goes up at speed?
Could be; I would check the system harness (both ends disconnected) for a short to ground before replacing the motor. 😉
