I had to use the inflatable spare tire last weekend and now got the replacement tire installed.  The problem/question I've removed as much of the air in the spare and replaced the belts around it to shrink it a bit further but the spare still won't fit as it did horizontally on the floor of the "frunk"
Remove the interior from the valve, instal one or two tensioning straps, which used in the transport sector, around the rim/spare tire and tighten well, let it rest overnight. The spare wheel will now fit, replace the interior back in the valve. Otherwise it will be an uneven fight, success.
If you have a vacuumpomp available,this is the best solution.
