On my 955 2004 cayenne turbo, I was going to replace the intake manifold bolts but I cannot figure out how they come out. I loosened the rubber seal but the casing around the bolt will not allow it to slide out. Are they permanent sealed in or does the intake have to be separated to get it out.
  • 2 months later...
According to Pelican Parts you just tap them out.
"If the stud is broken off in the head, you can remove the head and extract it. Then install new stud / helicoil if needed. - Nick at Pelican Parts"
"Use a screwdriver to tap out old manifold bolt and press new one in."
"They are held in with rubber grommets. Just push them out. - Nick at Pelican Parts"
