I am upgrading my long dead AC system to R134 through the Griffiths upgrade compressor, condensor, dryer.
The question is what was the original oil used in the system?
My worry is mixed reports about remnant oil in the evaporator located underneath the dash.  Some say mixing oil types may turn to varnish ... if this is true, it could mean the end of the evaporator and maybe the rest of the system.
Has anyone upgraded their system?
I would suggest contacting the compressor manufacturer and ask their advice as most of the PAG oil function  is in protecting the compressor components.
You can also purchase an AC flushing kit, which uses a solvent run thru the system to remove oil and any metallic debris from the system, and leave the entire system clean as it was new.
