I would like to remove and replace a one of the large pins in the DME plug. I can disassemble the plug, but cant see how to remove the pin.  Same with the X59 white plug.
These pins typically have a small pop up tang that needs to be depressed and held down while they are extracted.  That requires a set of pin removal tools:
