I put in some new coilovers over memorial day on my 2001 996 C4 Coupe 6 speed and in the process let my battery die. Ever since it died, the driver's window doesn't come up and is stuck down all the way. When I try to put it up with the switch, it clicks in the door, but no movement, whirring, anything. The window worked perfectly prior to the battery dying. I think I tried to put the window down when the battery was just about dead, and pressing it was the last straw. When I jumped the battery, I think the driver's window was part way down if that's of any consequence. It would have gone all the way down during the battery jump process.
I've tried a number of tricks to get it to go including the following, however none have worked:
  • Undoing battery negative terminal then trying the window reset (hold down for 10 seconds, and up for 10 seconds)
  • Undoing battery and unplugging the Comfort Control Module under the driver's seat (there was one plug I couldn't get undone)
  • Checking the switch itself by using it on the passenger window that does work
  • Closing the door firmly while pressing up on the switch to jolt the window motor
  • Hitting the door near the motor while pressing up on the switch to jolt the window motor
  • Checking fuses to see if they work (I didn't try the multimeter on the fuses, but when I took them out, the passenger window stopped working and then it worked when I put the fuses back, so I assume they are fine. Visual inspection doesn't show any issues)
  • Pulling the door panel off to check the window motor - The regulator looked fine (not stretched out), however I couldn't really access the motor because with the window down, I can't get the speaker out of the door, meaning I can't get to the motor itself
I've checked a gazillion forums and haven't gotten to an answer. Does anyone have any bright ideas as to what else I could try?
:welcomeani:
Your car is 24 years old things are going to wear out or fail.
Sounds like a bad window regulator to me - a fairly common problem on older cars.
