U0404 - Software incompatibility with transmission control module - signal implausible.
A U0404 code on a Porsche 997 indicates an issue with the Electronic Shift Module (ESM). Specifically, it means the Powertrain Control Module (PCM) or Transmission Control Module (TCM) has received implausible data from the ESM.
 The ESM itself could be malfunctioning, sending incorrect data. The Transmission Control Module could also be the source of the problem, either by not processing the ESM's signal correctly or being faulty itself. Damaged wiring, loose connections, or corrosion in the wiring harness connected to the ESM can also cause communication errors.
Some deeper diagnostics are going to be needed to decide how to proceed.............
