Back in 2011 a previous owner of my 1999 Boxster replaced the bad 2.5 with a 2.7 from a 2001 Boxster.  It appears to be a professional installation (or at least carefully done), and it has around 35,000 miles on it since then.  The ECU has also been reprogrammed (by ECU doctors) for the 2.7.  However, it smells like it is running rich and I fear will start fouling out spark plugs.  I'm planning to replace the two upstream O2 sensors because those are responsible for controlling the air+fuel mixture.  My question is whether I should buy O2 sensors for a 1999 Boxster with a 2.5, or a 2001 Boxster with a 2.7.  I've checked a couple sources and the part numbers given for each are slightly different.
What is community thinking on this?
Welcom to RennTech :welcomeani:
Before considering replacing ANYTHING, first do some diagnostics: Using a Porsche specific scan tool, check for any pending codes, check all four O2 sensors for function and voltage readings, check the MAF for voltage readings, and run A/F ratios; then and only then will you have the information about what, if anything, needs to be addressed.
That's a fair point @JFP in PA, thank-you.  Off topic here, but can I ask if you have a recommended Porsche specific scan tool?  Or point me to a thread where that is discussed?
For the part time DIY user, the Durametric system is probably the best choice, it is a software based system that runs off any Windows based laptop and can do perhaps 85% of what the factory PIWIS system can do but without the $20,000 starting price tag of the PIWIS system.  There are a lot of OBD II scan tools that claim to be Porsche specific, but we are yet to see one that really is or can even come close to the Durametric software.
As for how to test, "search" is your friend.  There are multiple threads and videos both on this website as well as others that can walk you thru the processes to evaluate your potential problems.
