The engine makes a tic-tic noise from some hydraulic lifters, only when the engine is running for a while above 3,000 rpm (on the highway, for example). After replacing all the hydraulic lifters, the noise has improved somewhat, but the noise still persists, so I think it must be an oil pressure problem at high rpm.
I also replaced the oil pump relief valve. Any ideas what it could be, what I should check, and how?
This noise from the hydraulic lifters started after repairing a water-oil mixture problem, so I think the water must have affected some component.
What test pressure are you seeing when you attach a mechanical gauge in place of the pressure sender?
Are you seeing the presence of ANY ferrous metal specs in your oil filter or oil?
