Help needed! 2 year owner of the 1998 986 base, no real issues then last month the battery dies. Charged via charger, after that left on a tender. 1 week later, no AC. I have gone thru all of the motions, no codes other than 02 sensors to address, fuses check, new relay check (no change), static AC pressure check 120/35 (compressor not running, holds, no leaks present). Separate 12v source to check AC clutch check (pulls in), 12v at low pressure switch - is there another high pressure switch im missing? 12 volts at relay. CCU works as intended- i think, blower works, snowflake etc.. What am i missing?! next step is to remove controls, clean contacts and reinstall. Did i fry something with the battery tender? All help is appreciated!!!
17 hours ago, JFP in PA said:
Should be under the windshield cowling where the battery sits.
I found that one, have 12 volts at the connector, is there any readings i should be checking for on the switch itself? i.e. ohms, continuity etc? thx
Both the low and high pressure switches must be in the closed position in order for there to be a complete electrical circuit to engage the compressor clutch.  I would be looking for continuity across the terminals on the switch, which would indicate that closed position.
