Hi guys new to the forum.. My stepson picked up a '99 boxster and the guy said it won't start ever since the radio was stolen. We've checked all the relays. We've got spark to the spark plugs. The fuel pump will work if I bypass it but we can't get power to the fuel pump. Any suggestions? Thank you in advance
That sounds like an immobilizer issue. Someone with more extensive knowledge will probably step in here with more information. Do you have a repair manual for the car?
Welcome to RennTech :welcomeani:
The factory radio had a ground wire that had to be attached to the car's chassis under the dash as a simple anti theft device.  If that ground is not there, the immobilizer will prevent the car from starting.
  • Like 1
  • Thanks 1
