Hello, I just purchased a 2001 boxster and while I love the car at 60 mph and up there is a very loud whistle coming from towards the front of the car. Does anyone know what could be the cause and what I can do to fix it? Thank you so much!
:welcomeani:
Check to see that the front cargo lid is flush with the bumper. If it is not then the lid and/or bumper cover will need to be adjusted so that the lid does not catch air at speed.
6 hours ago, Loren said:
:welcomeani:
Thank you! I tried adjusting it all the way down and it didn't seem to fix the whistle, but when I adjusted it quite a bit up it seemed to help a little maybe? How do I know what height is the best or should I just do little changes over a longer drive to see what works?
1 hour ago, Loren said:
The front bumper cover and the front lid should be even.
Just put masking tape over the gap and it completely eliminated the whistle so you're absolutely right. I'll fiddle with the height and find which one works. Thank you so much!
