I have not been able to get the memory to work on my seats. (99 996) The power seats work fine, but I can not get the memory to hold. The fuse is good. Any ideas?
On my 1999 Boxster I set the set and mirror positions then press and hold the memory button. While I am holding the memory button I press one of the numbered buttons.
Then in order to put the seat into the memory position, I have to push and hold down the numbered button until the seat is in position.
Is that what you're doing?
Was the fuse you checked, the 7.5 amp. E2 fuse?
Don't forget you need to have the car running, or have the key turn to the on position to have the memory work. You must also hold the Memory button as you press #1 or # 2 to set position.
Stan
