Recently the Jagermobile (2006 C4S) would not start right away when warm, it would crank too long before starting or not start on the first attempt. It would eventually start, after a couple of attempts, but today it was a bit different. After starting it seemed to go into limp mode and the cruise control would not operate (No Check Engine Light). After I got home, I connected my Durametric into the OBD and found error code P0339 (see attached). I ordered a new sensor and will update the forum after I replace the suspect sensor.
I replaced the crankshaft position sensor and so far, seems to have fixed the problem. The engine has started a lot quicker when cold and when warm. One of the easier jobs I have done on this vehicle. Although I do have one of these lifts I purchased about 8 years ago, it sure helps a lot (made in Germany):
WWW.TWINBUSCH.DE
Scissor lifts
  • Like 1
