Hey everyone, first post here and fairly new owner of a 99 C2. I've finally been able to run some diagnostics with the Durametric and I got the following fault codes:
P1689 - Control unit faulty
P1531 - Camshaft adjustment bank 1
I suspect P1531 is a result of a faulty DME, but that is simply a guess. I should note that I've had issues connecting to Durametric and seeing the fault codes in the past (evidence of some kind of DME issue?) Also, I've been experiencing a bit of hunting idle and what feels like engine shuddering (misfires?) at idle.
I've cleaned the MAF, TB, and replaced the IACV. The vehicle had an aftermarket radio installed by the PO which I've recently upgraded to a double din unit, but I haven't changed any of the wiring.
I'm in need of some troubleshooting help. Would it be worthwhile to start with a replacement of the DME relay?
Thanks all!
dro
P1531 Actuator triggered, no active position.
- Open circuit in triggering wire.
- Open circuit in B+ supply.
- Actuator faulty.
P1689 is not a valid code for MY1999 C2. Perhaps check again?
